Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Basicly you will have to set it up for two/both devices.
This is clearly explained in the UserGuide for the BROne/BT.
When using the remote you will have to enter the List in order to tell the remote, which device is meant for the following commands.
Personally I find it extremely annoying - others may say, that it is something that one gets used to.
In addition - just as a hint…
Depending on how these two devices are set up/connected to each other, you may be able to start an integrated service of the BS1 via the BV11 using (one of the) the three MyButtons of your BROne/IR.
Thanks for clarifications.
Today, with my current BROne (IR version), Im able to conveniently either press "TV" to get to regular TV service or "MUSIC" button to get to Radio as a first choice or scroll down under "MUSIC" to get to e.g Deezer music.
Both Radio source and Deezer is "integrated" from the BS1 to be available sources in BV11.
(I know both those sources are available in BV11, but I think this works better.)
Reason for maybe changing to BROne BT is:
I had the same issue and have two remotes one for IR the other for BT saves all that messing about
