Using Beoremote One BT with a Beovision 11
Hiort
Sweden
Posts 2,895
Hiort Posted: Tue, Nov 16 2021 8:42 PM
I’m thinking of getting a Beoremote One BT to replace my Ir BROne.
I would like to use the remote for both to Beosound 1 GVA and my BV11.
I understand I need the remote to send IR to the BV11, but does that complicate things?
I just want to press TV to start the BV11 and press music or radio to play the integrated sources from BS1.
I also want to be able to select BS1 as device and select e.g radio channel.
Can anyone please explain how that would work on the remote.
Millemissen
Flensborg, Denmark
Posts 14,680
Basicly you will have to set it up for two/both devices.
This is clearly explained in the UserGuide for the BROne/BT.
When using the remote you will have to enter the List in order to tell the remote, which device is meant for the following commands.
Personally I find it extremely annoying - others may say, that it is something that one gets used to.
Millemissen
Flensborg, Denmark
Posts 14,680
In addition - just as a hint…
Depending on how these two devices are set up/connected to each other, you may be able to start an integrated service of the BS1 via the BV11 using (one of the) the three MyButtons of your BROne/IR.
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Nov 17 2021 9:10 AM
Thanks for clarifications.
Today, with my current BROne (IR version), Im able to conveniently either press "TV" to get to regular TV service or "MUSIC" button to get to Radio as a first choice or scroll down under "MUSIC" to get to e.g Deezer music.
Both Radio source and Deezer is "integrated" from the BS1 to be available sources in BV11.
(I know both those sources are available in BV11, but I think this works better.)
Reason for maybe changing to BROne BT is:
  • New fresh remote
  • Get one more shortcut button.
  • Ability to control BS1
So, with the setup I describe above, can I have the remote set to BV11 as my default product, meaning I only have to do an active choice (through LIST or similar) when I want to command BS1?
355f
cambridge/london
Posts 119
355f replied on Wed, Nov 17 2021 9:59 AM
I had the same issue and have two remotes one for IR the other for BT  saves all that messing about
Page 1 of 1 (5 items) | RSS
