Beosound Core with optical in audio from third party TV
Erik-nl
Posts 41
Erik-nl Posted: Sun, Oct 24 2021 9:10 AM
I have connected a third party TV to my Beosound Core via the optical input. However I have a delay on the sound. There is an option in B&O app to disable the audio delay, but it changes nothing.
Does anybody running a similar setup know if the “disable audio delay” is working (and I have a defect Core) or whether the option of disable the audio delay on optical in never have been fully implemented?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Oct 24 2021 9:18 AM
Erik-nl:
I have a Samsung TV connected to my Core Optical IN, audio delay is disabled and it is working fine.
Erik-nl
Posts 41
Erik-nl replied on Sun, Oct 24 2021 9:24 AM
Many thanks - so point towards a defect unit.
is auto sensing working on the optical in - core turns on when signal is detected?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Oct 24 2021 9:32 AM
Erik-nl:
Yes it is working as expected. When signal is received on the Optical port, Core wakes up or switches to Optical if another source was already playing.
Millemissen
Flensborg, Denmark
Posts 14,680
Erik-nl:
No, it rather points towards a setting that you obviously haven't made (yet).
Have a look here:
https://support.bang-olufsen.com/hc/en-us/articles/360041419912-How-do-I-make-settings-for-Line-in-sources-in-the-Bang-Olufsen-app-
Erik-nl
Posts 41
Erik-nl replied on Sun, Oct 24 2021 10:21 AM
Reboot was not enough - full factory reset - and it works.
Many thanks for quick feedback
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
