I have connected a third party TV to my Beosound Core via the optical input. However I have a delay on the sound. There is an option in B&O app to disable the audio delay, but it changes nothing.
Does anybody running a similar setup know if the “disable audio delay” is working (and I have a defect Core) or whether the option of disable the audio delay on optical in never have been fully implemented?
Erik-nl: Does anybody running a similar setup know if the “disable audio delay” is working (and I have a defect Core) or whether the option of disable the audio delay on optical in never have been fully implemented?
Many thanks - so point towards a defect unit.
is auto sensing working on the optical in - core turns on when signal is detected?
Erik-nl:is auto sensing working on the optical in - core turns on when signal is detected?
Erik-nl: Many thanks - so point towards a defect unit.
No, it rather points towards a setting that you obviously haven't made (yet).
Have a look here:
https://support.bang-olufsen.com/hc/en-us/articles/360041419912-How-do-I-make-settings-for-Line-in-sources-in-the-Bang-Olufsen-app-
Reboot was not enough - full factory reset - and it works.
Many thanks for quick feedback
