Have you connected any speakers to it yet? I had the same issue with mine, but it turned out, that it will only show the sound menu and allow you to adjust the volume once you connect a speaker to it.
/Dennis
Dennis:Have you connected any speakers to it yet? I had the same issue with mine, but it turned out, that it will only show the sound menu and allow you to adjust the volume once you connect a speaker to it. /Dennis
Had this with several BS5's. It is a software issue.After a recovery it will work for sure.
During booting you get the for recovery. Or via the servicemenu you can perform that. Music library and mots will be saved.
Beobuddy:During booting you get the for recovery. Or via the servicemenu you can perform that. Music library and mots will be saved.
Hello,
I think you can't use the arrow keys on the beosound 5.
It should work with any USB Keyboard conneted to one of the two USB Ports at the backpanel of the BM5 Unit.
Ralph-Marcus
RaMaBo:Hello, I think you can't use the arrow keys on the beosound 5. It should work with any USB Keyboard conneted to one of the two USB Ports at the backpanel of the BM5 Unit. Ralph-Marcus
You can connect a monitor to the BM5 Unit.
There's an unused DVI-I connector at the rear of the BM5. Just plug the monitor in, add a keyborad to one of the rear USB connectors of the BM5 and restart the BM5/BS5. right after the B&O logo it will show the Beomaster 5 Boot and Beomaster 5 recovery option for about 5 seconds.
RaMaBo:You can connect a monitor to the BM5 Unit. There's an unused DVI-I connector at the rear of the BM5. Just plug the monitor in, add a keyborad to one of the rear USB connectors of the BM5 and restart the BM5/BS5. right after the B&O logo it will show the Beomaster 5 Boot and Beomaster 5 recovery option for about 5 seconds. Ralph-Marcus
Razlaw: I can not get it to change from Beomaster 5 to Beomaster 5 Recovery. Perhaps that means there is a problem with it? Or am I doing something wrong? Nothing happens when I press the arrows.
You can enter the servicemenu on the BS5. Pointer on settings, then ><>< GO. The menu will enlarge with extra options. One of them contains also the option for recovery.
Beobuddy:You can enter the servicemenu on the BS5. Pointer on settings, then ><>
