Mates,
Anyone know if the commands for "Link" and "AV" can be accessed on the MLGW?
Specifically, I'm trying to trigger master room audio in a link room with an MLGW virtual command.
Jered
yes, you can create a special button for this.
I think you just create a virtual button and a macro that controls the audio device you want in the room (product) you want.
You define the product you want to control, the command, destination (audio- or video source) and the link (local- or default source/main room).
Stefan
It turned out to be much easier.
i send the v.aux command as an audio command (in the mlgw)
and voila. . no screen and audio comes on
useful to distribute apple tv/roku, etc. sound.
when is the bs3 going to distribute hdmi audio? is that even a possibility?
running the rca audio in addition to hdmi is sometimes a pita
