MLGW help needed
mjmedlo
Posts 922
mjmedlo Posted: Sat, Dec 22 2012 5:14 PM
Mates,
Anyone know if the commands for "Link" and "AV" can be accessed on the MLGW?
Specifically, I'm trying to trigger master room audio in a link room with an MLGW virtual command.
Jered
claudiu
copenhagen
Posts 193
yes,  you can create a special button for this.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sat, Dec 22 2012 6:46 PM
I think you just create a virtual button and a macro that controls the audio device you want in the room (product) you want.
You define the product you want to control, the command, destination (audio- or video source) and the link (local- or default source/main room).
Stefan
mjmedlo
Posts 922
mjmedlo replied on Sat, Feb 23 2013 4:25 PM
It turned out to be much easier.
i send the v.aux command as an audio command (in the mlgw)
and voila. . no screen and audio comes on
useful to distribute apple tv/roku, etc. sound.
when is the bs3 going to distribute hdmi audio? is that even a possibility?
running the rca audio in addition to hdmi is sometimes a pita
Page 1 of 1 (4 items) | RSS
