Adding Playmaker to my current system?
This post has 9 Replies | 2 Followers
Arkiminsu
Posts 2
Arkiminsu Posted: Sun, Aug 26 2018 9:14 PM
i am very new to this forum.
i just wonder what is the best way to connect Playmaker to my current system of Beovision 7 + Beolab 5 + Beosound 9000.
should it be connected to beosound 9000’s aux connection?
or be connected to Beolab 5’s 2nd powerlink (beolab5 has 2 powerlinks on each)?
I also have another question.
is there anyway I can use 2 of digital connection, Beosound 9000 with digital out as well as Squeezebox digital out?
i like Beosound 9000 but streaming music is getting played more and more.
Thank you
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Aug 26 2018 10:42 PM
Not sure about the BL5 question, but when I was using a Playmaker with my BS9000 I had my turntable/phono-preamp connected to the line in of the PM, and the PM connected into the aux input of my BS9000. I've since replaced the PM with an Auralic Aries Mini with a SDD drive holding all my ripped music. No input on the Auralic,so I have to use a switch to change from listening to the turntable to the Auralic.
Jeff
elephant
AU
Posts 8,219
elephant replied on Mon, Aug 27 2018 1:54 AM
Arkiminsu:
I doubt that.
The 2xPL connections are used to support daisy chaining. See this page from the BeoLab 5 User Guide on the B&O site:
Using the Digital In or Line In to complement the PoweLinks may be a better choice.
You will find the BeoLab will prioritise one signal detection over another.
The sync cable may be another BL5 specific complication.
BeoNut since '75
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Arkiminsu,
Welcome to Beoworld!  Please connect the PlayMaker to the Aux socket of the Beosound 9000 with this cable to play it through your speakers without needing any changes to the existing setup:-
https://soundsheavenly.com/playmaker-and-essence-wireless-streaming/84-374-rj45-to-aux-input-cable-airplay-on-your-bo-system.html#/4-length-3m
Please select "A.AUX" via the LIST button on your Beo4 remote control to play the PlayMaker.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
danielshen
Posts 78
I do have the same question. I will work on that based on your advice.
Arkiminsu
Posts 2
Thank you very much.
it was very helpful.
jusr for the update, I did connect  PM to second
it is working ok except the volume control working.
so the best way will be that PM connect to 9000’s
Posts 2,165
If you don’t have control of the volume then the PlayMaker may have been connected to a Powerlink socket instead of the Aux socket.
Kind regards Steve.
Steve.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Sep 2 2018 4:16 PM
Which volume control? You can set the PM to a fixed volume or variable volume, if he's talking about the PM's volume control.
Jeff
Posts 2,165
Hi Jeff,
If the PlayMaker is accidentally plugged into a Powerlink socket on the Beosound 9000 instead of the Aux socket, then the sound will come through the speakers, but the Beosound 9000 volume control won't work for the PlayMaker.
This is a common issue, as the sockets are hidden under the 9000 and the plug will fit all three DIN sockets, but the 9000 can only control the PlayMaker volume when the Aux socket is used.
As you mentioned, the PlayMaker volume should work via the app as long as it has been set to Variable output.
Steve.
mauribits
Posts 3
mauribits replied on Wed, Nov 24 2021 1:07 PM
please advise if you can also connect beoplayer on beosound 5
Page 1 of 1 (10 items) | RSS
DigiCert Secured Site Seal
