Hi
Got this old nice AV 9000. There are few problems with it. First a stuck tape inside player. It just would not eject. Any easy way to get it out? Or if I have to open the player do I have to lift TV away then?
Second.....stand is not working. Motor is running and some loud squeaking but not turning. Some belt or?:)
Suggestions?:)
Ok........stand problem solved. Belt broken........but that video. How to get in there?
OK.....simple and easy but now need service manual for vcr. Suppose it is Beocord VX7000? Possible to find from here?
Yes, it`s a VX7000 - you will find manuals for the Beosystem AV9000 on the product/ manuals site on Beoworld.
https://www.beoworld.org/manuals_view.asp?pid=865
hope this helps
Stefan
There was a good repair thread on the archived forum, but sadly the photos have disappeared (perhaps they can be recovered or found elsewhere): https://archivedarchivedforum2.beoworld.org/forums/t/24191.aspx
Also, I often watch this chap's YouTube videos for repair tips. He works without manuals and it's interesting to see his approach - he has fixed a few B&O items, but sometimes it's a bit hit and miss. Here's his VX7000 video: https://www.youtube.com/watch?v=-SxzTsXzpq0
Yep, found that same. Actually got some hints concerning about right positions of few parts in loading mechanism.
Still have that problem with loading. There is some kind of a bar under those rollers and wheels underside of player.
That bar don't move enough and prevents movement of a small hook. That hook allow two wheels to connect and loading don't work.
It's a question about 2 mm. If I give some pressure to right direction to the bar everything works just fine.
I can't find any faults from plastic linkages nor wheels.
