Hello again, another " newbie " question I'm afraid.
But first, just to say, I'm finding my way around this forum with regard to responding to answers. I THINK I've thanked everybody who has helped so far, I have tried, but in case I haven't managed it, my apologies.
Ok. I have a Beocentre 9500 with Beolab 6000 speakers. Would somebody advise which leads I need for those speakers and a 9500 phono please?
Thank you.
In addition - if I may - please be aware, that Powerlink cables carry both left and right channel.
Means: you will have to set the switch on the BL6000’s to L or R according to their positioning im room.
Thank you for that Millemissen. I'm grateful.
Thank you for that Lawrence, I'm grateful.
Hi jonfey,
I have the Powerlink mk.3 cables you need available, please either click on my sponsor link below or use this link to go directly to the cables you need (my site is closed for maintenance until Monday morning):-
https://soundsheavenly.com/powerlink-8-pin-din-connection/20-266-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/1-length-05m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Thank you Steve.
Events have overtaken us now in as much as I have some. I got them prior to your post I'm afraid. I'm certain i'll need some more though as I have other items I want to connect. Thank you for your reply.
Thank you for your interest and answer BeoFrederick. Another contact made which is always helpful.
