Speaker leads.
This post has 8 Replies | 2 Followers
jonfey
Posts 13
jonfey Posted: Fri, Feb 11 2022 5:31 PM
Hello again, another " newbie " question I'm afraid.
But first, just to say, I'm finding my way around this forum with regard to responding to answers. I THINK I've thanked everybody who has helped so far, I have tried, but in case I haven't managed it, my apologies.
Ok. I have a Beocentre 9500 with Beolab 6000 speakers. Would somebody advise which leads I need for those speakers and a 9500 phono please?
Thank you.
lawrencejmcook
Posts 742
Hi Jonfey,
You need a pair of 8-pin DIN Powerlink Mk2 or Mk3 cables between the BeoCenter 9500 and the BeoLab 6000s.
If by “9500 phono” you mean a Beogram 9500 record player, then it should have its own 7-pin DIN captive cable that plugs into the Phono socket on the BeoCenter 9500.
Lawrence
Millemissen
Flensborg, Denmark
Posts 14,680
In addition - if I may - please be aware, that Powerlink cables carry both left and right channel.
Means: you will have to set the switch on the BL6000’s to L or R according to their positioning im room.
jonfey
Posts 13
jonfey replied on Fri, Feb 11 2022 10:13 PM
Thank you for that Millemissen. I'm grateful. Smile
jonfey
Posts 13
jonfey replied on Fri, Feb 11 2022 10:14 PM
Thank you for that Lawrence, I'm grateful. Smile
BeoFrederic
Posts 276
The go-to guy for B&O-related cables is Steve @ Sounds Heavenly, or just go to his website. He’s a sponsor of this site, btw.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi jonfey,
I have the Powerlink mk.3 cables you need available, please either click on my sponsor link below or use this link to go directly to the cables you need (my site is closed for maintenance until Monday morning):-
https://soundsheavenly.com/powerlink-8-pin-din-connection/20-266-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/1-length-05m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
jonfey
Posts 13
jonfey replied on Sat, Feb 12 2022 12:36 PM
Thank you Steve.
                              Events have overtaken us now in as much as I have some. I got them prior to your post I'm afraid. I'm certain i'll need some more though as I have other items I want to connect. Thank you for your reply.  Smile
jonfey
Posts 13
jonfey replied on Sat, Feb 12 2022 12:38 PM
Thank you for your interest and answer BeoFrederick. Another contact made which is always helpful. Smile
Page 1 of 1 (9 items) | RSS
