In a recent question and answer session on this forum you have helped me to get my turntable working - needed a new belt and the swing arm needed some lubrication and that is all good
I now have a turntable that revolves but here is the next question if anyone can help -
The turntable does not revolve at a constant speed. At a particular point you can hear it speed up and slow down around the correct speed and it seems to do it in a regular pattern as if there is a point in the mechanism that makes the system slow and then speed up. It is only a small increase/decrease but can be heard from the music from the record
Can anyone help me with a solution
Many thanks
Graham
Something rubbing on something else ?Transport screws completely undone ?Belt slipping ?
