Beogram 3000/5228
Graham
Portsmouth, England
Posts 3
Silver Member
Graham Posted: Sun, Dec 23 2012 11:55 AM
In a recent question and answer session on this forum you have helped me to get my turntable working - needed a new belt and the swing arm needed some lubrication and that is all good
I now have a turntable that revolves but here is the next question if anyone can help -
The turntable does not revolve at a constant speed.    At a particular point you can hear it speed up and slow down around the correct speed and it seems to do it in a regular pattern as if there is a point in the mechanism that  makes the system slow and then speed up.     It is only a small increase/decrease but can be heard from the music from the record
Can anyone help me with a solution
Many thanks
Graham
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Dec 23 2012 12:03 PM
Something rubbing on something else ?
Transport screws completely undone ?
Belt slipping ?
Page 1 of 1 (2 items) | RSS
