I have not had the unit long it was preowned everything seems to work ok but I have noticed when I use the random it plays 3-4 tracks before switching itself off it also happens if its on link the BL2000 switches off with the main unit.
Any suggestions would be appreciated.
Mark
Hi there I am not sure but I wonder if you can set it so it plays a certain amount of songs then turns off? Or maybe you can set it to play for a certain amount of time then it turns off? Have you downloaded the manual?
When you play the same cd's straight through they have no problems ? Are you using original cds or copies ?
Original CD's and they play through fine it's just on random the problem occurs
Plumber - I am clear out of ideas, hopefully someone else has a suggestion.
