BS9000 Random problem
This post has 4 Replies | 0 Followers
plumber77
Posts 76
plumber77 Posted: Sat, Dec 22 2012 4:17 PM
I have not had the unit long it was preowned everything seems to work ok but I have noticed when I use the random it plays 3-4 tracks before switching itself off it also happens if its on link the BL2000 switches off with the main unit.
Any suggestions would be appreciated.
Mark
2012martin
Posts 202
Hi there I am not sure but I wonder if you can set it so it plays a certain amount of songs then turns off? Or maybe you can set it to play for a certain amount of time then it turns off? Have you downloaded the manual?
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sun, Dec 23 2012 6:51 AM
When you play the same cd's straight through they have no problems ? Are you using original  cds or copies ?
plumber77
Posts 76
plumber77 replied on Sun, Dec 23 2012 11:03 AM
Original CD's and they play through fine it's just on random the problem occurs
valve1
Posts 1,502
valve1 replied on Sun, Dec 23 2012 4:47 PM
Plumber - I am clear out of ideas, hopefully someone else has a suggestion.
Page 1 of 1 (5 items) | RSS
