Masterlink > RJ45 Extension wih Network cable possible?
This post has 3 Replies | 3 Followers
TWG
Posts 1,672
TWG Posted: Fri, Feb 27 2015 9:11 PM
is the following setup possible:
- ML->RJ 45 cable ---> Ethernet cable ----> RJ 45 -> ML-cable.
I want to extend two ML->RJ45 cable with a network cable and an adapter like this:
http://www.conrad.de/ce/de/product/993563/RJ45-Netzwerk-Adapter-CAT-6-1x-RJ45-Buchse-1x-RJ45-Buchse-0-m-Metall?ref=searchDetail
Is that possible?
I would like to know before buying ;-)
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Feb 28 2015 4:30 PM
Yes, you can do - you'll obviously need two of the adapters you linked to.
The network cable between the two adapters will need to be of the S/FTP type (either Cat 6, Cat 6a or Cat 7 but must be S/FTP)
S/FTP means that is there is overall braided shielding (the S) and each pair has a foil screen (the F) which is also known as PIMF (pairs in metal foil)
Hope this helps.
Martin.
TWG
Posts 1,672
TWG replied on Sun, Mar 1 2015 11:24 AM
Hi Martin,
thank you and yes, that helps! :)
HHH
Posts 10
HHH replied on Sun, Mar 1 2015 11:30 AM
When you mention "Ethernet Cable" do you refer to double shielded CAT 7 cable or CAT 5e?
You can not use CAT5e for masterlink cable, it's not shielded and also dosen't have enough conductors to do ML (minimum 9 wires needed)
Page 1 of 1 (4 items) | RSS
