Hello
I just install beoplayer and tried with last Beoport, I still cannont register.I have a popup window that warns me that I am not registered.
Any solution available ?
Thanks in advance
Best regards
OLivier
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
BeoNut since '75
Hi
Thanks for your help.
I was connected to internet.
I tried to install beoplayer but without my beolink pc2 that I just purchased.
Do I need to plug it in order to register ?
olvisab: I just install beoplayer and tried with last Beoport, I still cannont register.I have a popup window that warns me that I am not registered.
BeoPlayer as well as BeoPort for PC version 5.04 is compatible to 32 and 64 bit versions of XP /Vista and WIN 7.
The BeoPort version needs a BeoPort (or BeoLink PC2) box, already plugged to the mains, to be connected at the "right time" to the computer to install the appropriate USB driver (as described by elephant)To fully access internet radio you'll have to register on the B&O site .I'd de-install the recent BeoPlayer / BeoPort installation and start from the scratch ...
Thanks for this advice, I will try with the beolink pc2 plugged.
