beoplayer/beoport, can not register
olvisab
Posts 1,391
olvisab Posted: Wed, Feb 6 2013 6:55 PM
Hello
I just install beoplayer and tried with last Beoport, I still cannont register.I have a popup window that warns me that I am not registered.
Any solution available ?
Thanks in advance
Best regards
OLivier
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
elephant
AU
Posts 8,219
Did you install it while connected to the Internet ?
The install sequence is important - from memory - you need to wait until the software tells you to attach the USB, and not attach it first. I.E. the reverse of what most Windows's people do.
BeoNut since '75
olvisab
Posts 1,391
olvisab replied on Wed, Feb 6 2013 9:14 PM
Hi
Thanks for your help.
I was connected to internet.
I tried to install beoplayer but without my beolink pc2 that I just purchased.
Do I need to plug it in order to register ?
Vienna
make an educated guess
Posts 1,090
Vienna replied on Wed, Feb 6 2013 9:14 PM
olvisab:
BeoPlayer as well as BeoPort for PC version 5.04 is compatible to 32 and 64 bit versions of XP /Vista and WIN 7.
The BeoPort version needs a BeoPort (or BeoLink PC2) box, already plugged to the mains, to be connected
at the "right time" to the computer to install the appropriate USB driver (as described by elephant)
To fully access internet radio you'll have to register on the B&O site .
I'd  de-install the recent BeoPlayer / BeoPort installation and start from the scratch ...
olvisab
Posts 1,391
olvisab replied on Thu, Feb 7 2013 9:05 AM
Thanks for this advice, I will try with the beolink pc2 plugged.
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
