I have a Beocenter 2200 problem. The balance between the speakers is way off.
Is it a problem with the unit itself that would cause this. I have switched the speakers to see if it was a fault with them but it is not. To get an equal balance the left speaker is at number 2.5ish.
What could be causing this?
Probably a dying capacitor somewhere in the signal path.I remember some of them sitting at the perimeter of the round cutout for the tuning gear, they arequite small physically and are known to cause problems like this.
I have the same problem with my 2200. And it's only 27 years old!
I guess it will give up altogether one day but until then it stays - it was the first item of B&O equipment I owned and I still have a soft spot for it even though it now lives in a bedroom and only ever gets used for occasional radio play.
