Beolab 6000 replacement/removable tops?
JulianJ
Posts 66
JulianJ Posted: Mon, Feb 11 2013 12:51 PM
All,
Does anyone have any information on how the Beolab 6000 case is constructed? I'm especially interested in the top of the aluminium cabinet and how it is assembled?
I have found an image on the internet of what appears to be the top available as a spare part. Does anyone know if this part is easily removed or replaced?
Ive searched hard for an exploded diagram of the case or some diss-assembly instructions. Does anyone have any images or information they could share?
Thank you in advance!
Regards
Julian
JulianJ
Posts 66
Here is a better image of the top I would like to remove.
MartinW
Posts 389
MartinW replied on Mon, Feb 11 2013 1:18 PM
Hi Julian, they are pretty easy to replace. Slide the fret up and off, undo the screws at the top of the speaker face that hold the top caps in place, then prise the caps off as they are mostly self adhesive.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Remove the fret by sliding upwards
Remove front panel containing the port and tweeter ( remove the tweeter first if you prefer)
Remove screw in centre of underside of top cap
Remove top cap (double sided tape! You may require a suitable lever to overcome)
Easy 15 minute job
Regards Graham
JulianJ
Posts 66
JulianJ replied on Mon, Feb 11 2013 4:35 PM
Thank you Gentlemen for the information. Are the frets fairly easy to remove without damaging them?
Regards
Julian
JulianJ
Posts 66
Regards
Julian
joeyboygolf
Posts 4,188
Easy, just slide them upwards and they will fall off!
Regards Graham
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Mon, Feb 11 2013 10:47 PM
A word of caution when removing the frets make sure that you don't bend the small metal lugs on the reverse of the fret. They are fairly easy to bend and once out of shape are very difficult to re-fit to the speaker.
Opman
Page 1 of 1 (8 items) | RSS
DigiCert Secured Site Seal
