So I solved my previous question myself, but I don't think I can take this on my own!
If possible I would like to get it running. The video output and the menu work, but nothing tape related (play, eject, fastforward). It is connected to a MX7000 in socket AV1.
Would this be possible to diagnose somehow? Maybe someone can lend a hand.
I have same issue with my V8000. it take the VHS but no playing is engaged afterwards and no eject possibility ... I need two open it and manually retrieve the VHS
did you solve your issue on your side ?
