BEOCORD V8000 does not play, nor will it eject the tape
LegalDrokz
Posts 6
LegalDrokz Posted: Fri, Dec 18 2020 11:30 AM
So I solved my previous question myself, but I don't think I can take this on my own!
If possible I would like to get it running. The video output and the menu work, but nothing tape related (play, eject, fastforward). It is connected to a MX7000 in socket AV1.
Would this be possible to diagnose somehow? Maybe someone can lend a hand.
Beofanatic
Posts 4
I have same issue with my V8000. it take the VHS but no playing is engaged afterwards and no eject possibility ... I need two open it and manually retrieve the VHS
did you solve your issue on your side ?
Beofanatic
Posts 4
Page 1 of 1 (3 items) | RSS
