Beosound Ouverture - MCL2p -Link
Gone_Fishing
Posts 5
Gone_Fishing Posted: Sat, Mar 2 2013 12:17 PM
I have an old Beocenter 2500 and a MCL link system (extra speakers kit) connected via Powerlink cable and a MCL2P amplifier.
Does anyone know if I can replace the Beocenter 2500 with a Beosound Ouverture (without having to replace the MCL2P with a ML-/MCL converter)?
All information is appreciated
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Mar 2 2013 12:34 PM
It may be possible to use a BeoLink convertor which is cheaper than an ML/MCL convertor. You would need ML cable from the Ouverture to the BeoLink convertor then data link to run your existing MCL link system. I don't know if it will work as I have never tried that combination. Just a thought. Hopefully some one else can either confirm or suggest an alternative solution.
Regards
Opman
Page 1 of 1 (2 items) | RSS
