I have an old Beocenter 2500 and a MCL link system (extra speakers kit) connected via Powerlink cable and a MCL2P amplifier.
Does anyone know if I can replace the Beocenter 2500 with a Beosound Ouverture (without having to replace the MCL2P with a ML-/MCL converter)?
All information is appreciated
It may be possible to use a BeoLink convertor which is cheaper than an ML/MCL convertor. You would need ML cable from the Ouverture to the BeoLink convertor then data link to run your existing MCL link system. I don't know if it will work as I have never tried that combination. Just a thought. Hopefully some one else can either confirm or suggest an alternative solution.
Regards
Opman
