Quick question. Thought I would find it easily on this forum, nut no.
Can I access the music files on a BeoMaster 5 via an Apple TV, which is on the same network?
Hi Griebel,
congrats to your 100th post
No, you can not...
That is...if you jailbreak the ATV, it would be possible to access the BM5-server via the ATV.
Or... if you use an iDevice with a DLNA-app (e.g. PlugPlayer), you can access the server and airplay the files to the ATV.
Greetings Millemissen
Jailbreaking is one option - the other one is easier/better.
Please send a link to the thread where you "sought help".
Never heard that this shouldn't be possible - don't give up.
Here is the link to the mentioned thread: http://archivedforum2.beoworld.org/forums/t/4354.aspx
I absolutely have no clue on what did happen between the BM5 and the iDevices (tried several). They don't want to talk to each other anymore!
Sorry for asking:
But...
...have you changed any router-settings/got a new router/installed an AirportExtreme/AirportExpress as hotspot etc?
Did it work after you have setup the ATV?
