Beo 5 remote spares
This post has 4 Replies | 2 Followers
johnheartfield
Posts 20
johnheartfield Posted: Fri, Apr 12 2013 1:00 PM
The Hoover had just eaten the power cable to my beo 5 remote. No problems with the remote itself or the desktop charger. Does anyone know if it is possible to get a replacement? Thanks
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
A Very Warm Welcome to Beoworld.
Yes, replacement power cables are available, please confirm which part of the cable as it comes in two parts namely:-
  • The cable from the base to socket
  • From mains adapter to plug
Regards Keith....
johnheartfield
Posts 20
A return after a long absence really. Thank you for the reply. It is the last part of the cable that runs to the power socket - so it has a three pin plug at one end and what looks like a small USB type connector that goes into the cable that leads to the charger. John
Keith Saunders
Posts 5,495
The typical price would be about £37 including VAT in the UK
Regards Keith....
johnheartfield
Posts 20
Thank you again Keith. Suppose no one has an old cable from a broken Beo 5 I can buy😊?
Page 1 of 1 (5 items) | RSS
