The Hoover had just eaten the power cable to my beo 5 remote. No problems with the remote itself or the desktop charger. Does anyone know if it is possible to get a replacement? Thanks
A Very Warm Welcome to Beoworld.
Yes, replacement power cables are available, please confirm which part of the cable as it comes in two parts namely:-
Regards Keith....
A return after a long absence really. Thank you for the reply. It is the last part of the cable that runs to the power socket - so it has a three pin plug at one end and what looks like a small USB type connector that goes into the cable that leads to the charger. John
The typical price would be about £37 including VAT in the UK
Thank you again Keith. Suppose no one has an old cable from a broken Beo 5 I can buy😊?
