So I finally found a cheap Beomaster 5000, the seller didn't know you needed special cables and thought it was broken. What I don't know is if there is a ground for the turntable. I have an 1800 that has a ground cable but don't see a ground anywhere on the panel, just an antenna hook up. Do I need to use the ground?
Thanks.
You definitely need to ground it. You'll see the ground wire connector near the two black 'U'-shaped jumper connectors.
