Ground for Beomaster 5000?
This post has 1 Reply | 0 Followers
JohnnyR
Posts 1
JohnnyR Posted: Fri, Mar 8 2013 1:46 AM
So I finally found a cheap Beomaster 5000, the seller didn't know you needed special cables and thought it was broken.  What I don't know is if there is a ground for the turntable.  I have an 1800 that has a ground cable but don't see a ground anywhere on the panel, just an antenna hook up.  Do I need to use the ground?
Thanks.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
You definitely need to ground it.  You'll see the ground wire connector near the two black 'U'-shaped jumper connectors.
Page 1 of 1 (2 items) | RSS
