Hi Räuber,
When you setup your main system for Beo4 Navi, using the main system from link room is limited, as linking does not support the navi button, as far as I remember. So using Beo4 Navi in link room will not help as the navi buttons will not be sent to main room.
I once used it in this way, but then reverted main system to standard beo4 without navi button. In the moment a cannot test your desired configuration, maybe someone else can test or confirm.
hfat
