Beo 4
Raeuber
Germany
Posts 2,542
Raeuber Posted: Mon, Apr 1 2013 1:57 PM
Hi all,
actually I use two old Beo 4 without navy button with my BV 7 in main room and BV 10 in link room (connected via masterlink).
I would like to replace one Beo 4 by a new Beo 4 with navy button, because remoting the internal bluray player of BV 7 with the old Beo 4 is not much fun (you have always to press the yellow button before a command).
Of course I can use my BV 10 with Beo 4 without navy button and BV 7 with Beo 4 with navy button. But my question is:
Can I then still remote my BV 7 from link room (BV 10) with Beo 4 without navy button? Or I will need two new Beo 4 with navy button?
Thanks for your answer.
Greetings
Räuber
hfat
Vienna, Austria
Posts 663
hfat replied on Mon, Apr 1 2013 4:13 PM
Hi Räuber,
When you setup your main system for Beo4 Navi, using the main system from link room is limited, as linking does not support the navi button, as far as I remember. So using Beo4 Navi in link room will not help as the navi buttons will not be sent to main room.
I once used it in this way, but then reverted main system to standard beo4 without navi button. In the moment a cannot test your desired configuration, maybe someone else can test or confirm.
hfat
Page 1 of 1 (2 items) | RSS
