Buying advice Beolab 8000 systems
tamtapir
Örebro, Sweden
Posts 521
tamtapir Posted: Sun, May 19 2013 8:54 AM
I am a speculator in Beolab 8000-system which includes the following components:
Beogram 8000
Beomaster 8000
Beocord 8004
Beovox Penta
What should I keep in mind to check and what defects should I avoid?
Peter
Earsdon
Posts 11,991
Peter replied on Sun, May 19 2013 6:58 PM
The first thing is the cosmetics - most of the electronics can be repaired but missing trim or damage will be a lot trickier.
Assuming therefore that the pieces look fine, see what works. The Beocord will almost always need new belts - obtainable. The Beogram is complex. If it works, great though it may well not work for long!! The 8000 in its earlier guises uses a tacho disc that deteriorates and will need to be replaced - obtainable. The capacitors can deteriorate giving a multitude of problems - fixable. The double sided tape holding the platter surround and lid on rot - easy to fix.
The big deal is the Beomaster - what does it do?
Peter
Playdrv4me
USA
Posts 477
I can't speak to the music players, but the BM8000 display should be checked for any missing segments, as this is a common problem. Next, test the audio output of course and ensure that both channels have equal volume with no distortion or crackling. Make sure the spring loaded door works well, I see these broken off a lot for some reason. Also ensure that the volume control rolls smoothly throughout the volume range with no stopping or jumping. Same for the tuning dial and the tuner. Make sure you can set a couple of station presets and test all the buttons, sometimes you will get strange behavior from the button pad if the ribbon cable is frayed or damaged internally.
tamtapir
Örebro, Sweden
Posts 521
tamtapir replied on Mon, May 20 2013 4:10 PM
Peter:
Playdrv4me:
Thank you, Peter and Playdrv4me for the information. I dont know much about this set yet but the owner says that a few defects occured when he was testing it after 10 years or so in the closet. I will visit him on saturday and knows more for sure then.
tamtapir
Örebro, Sweden
Posts 521
tamtapir replied on Wed, May 22 2013 6:40 PM
The seller just called me and told that the system is sold.
Curse him, He promises me that I could visit him on Saturday. Stupid f*ck
Problems with the set:
Bad reception over radio
Some issue with the volume adjustment.
Beocord needed new belts
*sic*
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Wed, May 22 2013 7:29 PM
Bummer :-(
Playdrv4me
USA
Posts 477
tamtapir:
*sic*
Sorry to hear this. Here's to a better one coming along.
Page 1 of 1 (7 items) | RSS
