new member! beocenter 7000 question
rogerfederer
Posts 7
rogerfederer Posted: Fri, May 17 2013 3:29 PM
i have a beocenter 7000 i am trying to get working.  the fm and cassette work fine.  i have the right speaker cables and get good sound.
the problem is the turntable.  everything funtions except the left channel.  it is not the cartridge and i just got a new working mmc20en and still no left channel.  tried deoxit on the contacts on the tonearm.
any other ideas?
thanks for any help!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, May 18 2013 6:46 AM
Welcome to Beoworld !
A bit difficult to diagnose at distance.
Could be a pulled or skewed connector somewhere, could be a problem in the RIAA preamp
or the source selector.
Could also be a broken wire inside the tonearm.
You will have to poke around a bit inside, follow the signal path backwards from the amplifier
and find where the signal gets lost.
rogerfederer
Posts 7
OK, thanks.  makes sense.
wish me luck!
Page 1 of 1 (3 items) | RSS
