i have a beocenter 7000 i am trying to get working. the fm and cassette work fine. i have the right speaker cables and get good sound.
the problem is the turntable. everything funtions except the left channel. it is not the cartridge and i just got a new working mmc20en and still no left channel. tried deoxit on the contacts on the tonearm.
any other ideas?
thanks for any help!
Welcome to Beoworld !
A bit difficult to diagnose at distance.Could be a pulled or skewed connector somewhere, could be a problem in the RIAA preampor the source selector.Could also be a broken wire inside the tonearm.You will have to poke around a bit inside, follow the signal path backwards from the amplifierand find where the signal gets lost.
OK, thanks. makes sense.
wish me luck!
