The short answer is YES you can..
However, if they are to be in the same room make sure you set the option settings correctly so they don't both get triggered by your Beo4 remote.
Regards Keith....
Keith Saunders: The short answer is YES you can.. However, if they are to be in the same room make sure you set the option settings correctly so they don't both get triggered by your Beo4 remote.
IR conflict will only happen, if speakers are connected to the BSd 9000 via PowerLink..Without speakers connected via PowerLink a BSd 9000 disables IR and selects "A.OPT" "0" automatically.
