Beolab 3500
This post has 3 Replies | 2 Followers
alijiang
Posts 13
alijiang Posted: Sat, May 18 2013 11:41 AM
Hello,
I have a stand alone mk3 beosound9000 With no speaker. My question is can I buy a beolab 3500 and connect both through master link? So That I can use beolab 3500 as the bs9000 speaker?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
The short answer is YES you can..
However, if they are to be in the same room make sure you set the option settings correctly so they don't both get triggered by your Beo4 remote.
Regards Keith....
Vienna
make an educated guess
Posts 1,090
Vienna replied on Sat, May 18 2013 2:40 PM
Keith Saunders:
IR conflict will only happen, if speakers are connected to the BSd 9000 via PowerLink..
Without speakers connected via PowerLink a BSd 9000 disables IR and selects "A.OPT" "0" automatically.
alijiang
Posts 13
alijiang replied on Sat, May 18 2013 2:55 PM
Thanks. So I can use both in the same room With no pb by masterlink
Page 1 of 1 (4 items) | RSS
