Last year I bought two Bosscom BossDim Wall-dimmers but to late I realized that they had danish fittings. I ordered two more with euro-mounts that works in Sweden but I have yet to install those two either.
All of them are in silver-colour and I am going to sell the ones for danish wall mounts (FUGA?) since I can not use them any way, and maybe one or both of the euro-ones also (havent decided yet).
The dimmers work with the Beo4 remote so you can control the light level and turn on/off the lights. There is also a sleep timer-function (30 minutes) that you can use if you want.
None of the dimmers have ever been used or installed.
The ones for danish walls specifications are:
The ones for euro/swedish walls specifications are:
Retail price for them is about 200 euro per piece (some charge as much as £280!). The lowest price I can find is on eBay (£160/€190).My price is 1025 SEK (€120 / £101) per dimmer or some kind of trade perhaps. Plus shipping from Sweden.On the picture you see two of the danish-wall designed dimmers with smaller frames and one of the dimmers with euro/swedish wall mount that is a bit larger.More info: BossDim Wall (danish)BossDim Wall EuroUnoDim250 (the name on the back of the euro-model)
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
No answers so perhaps the price is too high. Anyone want to make an offer?
