BossDim Wall (danish and euro models) Beo4 compatible dimmers
Michael
Sweden
Posts 2,578
Michael Posted: Fri, May 3 2013 7:03 PM
Last year I bought two Bosscom BossDim Wall-dimmers but to late I realized that they had danish fittings. I ordered two more with euro-mounts that works in Sweden but I have yet to install those two either.
All of them are in silver-colour and I am going to sell the ones for danish wall mounts (FUGA?) since I can not use them any way, and maybe one or both of the euro-ones also (havent decided yet).
The dimmers work with the Beo4 remote so you can control the light level and turn on/off the lights. There is also a sleep timer-function (30 minutes) that you can use if you want.
None of the dimmers have ever been used or installed.
The ones for danish walls specifications are:
  • 20-160W Incandescent lamps
  • 20-160VA low voltage halogen via iron core transformer
  • 20-160VA low voltage halogen via electronic transformer
  • 230VAC, 50Hz
The ones for euro/swedish walls specifications are:
  • 20-250W, 20-250V, 230V, 50 Hz
  • Incandescent lamps or halogen lamps
  • low voltage halogen lamps via iron core transformer or electronic transformer
Retail price for them is about 200 euro per piece (some charge as much as £280!).
The lowest price I can find is on eBay (£160/€190).
My price is 1025 SEK (€120 / £101) per dimmer or some kind of trade perhaps. Plus shipping from Sweden.
On the picture you see two of the danish-wall designed dimmers with smaller frames and one of the dimmers with euro/swedish wall mount that is a bit larger.
More info:
BossDim Wall (danish)
BossDim Wall Euro
UnoDim250 (the name on the back of the euro-model)
Michael
Sweden
Posts 2,578
Michael replied on Thu, Jun 6 2013 8:37 PM
No answers so perhaps the price is too high. Anyone want to make an offer?
Page 1 of 1 (2 items) | RSS
