Beocenter 9500 with CD-door issues
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Mon, Jul 1 2013 11:47 AM
greetings all,
I am looking at a Beocenter 9500 - nice item, however the CD cover/door has to be opened/closed manually:-(
is this likely to be a mechanical prob only  and/or is there a designated board that controls  the movement of those covers and may have faulty components to be checked-out ?
furthermore, how difficult is it to get to this part without getting a fit or heart-attack??
grateful for any clue - suggestion - support from you guys
best from down-under..........ALF
Playdrv4me
USA
Posts 477
ALF:
greetings all,
Do you hear anything when you attempt to open the door? It's likely just needing a belt replacement.
Page 1 of 1 (2 items) | RSS
