greetings all,
I am looking at a Beocenter 9500 - nice item, however the CD cover/door has to be opened/closed manually:-(
is this likely to be a mechanical prob only and/or is there a designated board that controls the movement of those covers and may have faulty components to be checked-out ?
furthermore, how difficult is it to get to this part without getting a fit or heart-attack??
grateful for any clue - suggestion - support from you guys
best from down-under..........ALF
ALF: greetings all, I am looking at a Beocenter 9500 - nice item, however the CD cover/door has to be opened/closed manually:-( is this likely to be a mechanical prob only and/or is there a designated board that controls the movement of those covers and may have faulty components to be checked-out ? furthermore, how difficult is it to get to this part without getting a fit or heart-attack?? grateful for any clue - suggestion - support from you guys best from down-under..........ALF
Do you hear anything when you attempt to open the door? It's likely just needing a belt replacement.
