hi,
how can i open my beocom 6000 to clean it intensive.
i found the 2 screws inside the battery compartment, but i do not know how to get further?
grüße
There is a special tool that the dealer has to remove the cover. There are multiple pressure points that must be pressed simultaneously. It's very difficult to remove the cover without that special tool without breaking the plastic.
To remove the cover you need a tool which you can see HERE
Regards Keith....
A hard plastic card will do the job, that's all.
Brengen & Ophalen
