how to disassemble beocom 6000 ?
This post has 3 Replies | 0 Followers
manitou
germany
Posts 61
manitou Posted: Wed, Jul 17 2013 11:58 AM
hi,
how can i open my beocom 6000 to clean it intensive.
i found the 2 screws inside the battery compartment, but i do not know how to get further?
grüße
beojeff
USA
Posts 2,012
beojeff replied on Wed, Jul 17 2013 1:45 PM
There is a special tool that the dealer has to remove the cover. There are multiple pressure points that must be pressed simultaneously. It's very difficult to remove the cover without that special tool without breaking the plastic.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
To remove the cover you need a tool which you can see HERE
Regards Keith....
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Wed, Jul 17 2013 4:52 PM
A hard plastic card  will do the job, that's all.
Brengen & Ophalen
Page 1 of 1 (4 items) | RSS
