beocenter 9500
This post has 3 Replies | 0 Followers
lotus73jps
Posts 141
lotus73jps Posted: Wed, Dec 17 2014 12:04 PM
hi I have a beocenter 9500 I would like to know if I can record sound from a tv onto the tape deck off the 9500 thanks
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Dec 17 2014 7:47 PM
Yes if the tv is connected to the AUX/TV din input of the 9500.
Is it a B&O TV?
lotus73jps
Posts 141
lotus73jps replied on Wed, Dec 17 2014 11:16 PM
hi thanks for your reply the tv is a panasonic
solderon29
U.K.West Midlands
Posts 764
You just need a Din plug to RCA plug stereo cable.The cable needs connections to pins 3/5(screen to 2) at the Din plug,and the two RCA plugs go into the "sound/audio out" connection on most Panasonic tv's.
As per previous reply,connect the din plug to the TV/AUX socket of the Beocentre,and select AUX via the glass touch panel,or SHIFT-RADIO to open the aux mode via say,Beolink1000.
Nick
Page 1 of 1 (4 items) | RSS
