hi I have a beocenter 9500 I would like to know if I can record sound from a tv onto the tape deck off the 9500 thanks
Yes if the tv is connected to the AUX/TV din input of the 9500.
Is it a B&O TV?
hi thanks for your reply the tv is a panasonic
You just need a Din plug to RCA plug stereo cable.The cable needs connections to pins 3/5(screen to 2) at the Din plug,and the two RCA plugs go into the "sound/audio out" connection on most Panasonic tv's.
As per previous reply,connect the din plug to the TV/AUX socket of the Beocentre,and select AUX via the glass touch panel,or SHIFT-RADIO to open the aux mode via say,Beolink1000.
Nick
