greetings all,
I am having problems with my Beocenter 7000:
the display shows P and I can't change it, as it seem to be stuck in that mode/source.
is there any way of re-setting the micro-processor or another way of getting back to normal ??
naturally it could perhaps be something totally unrelated......... BUT WHAT ????
any help is appreciated
thank you so much :-))
cheers, ALF
This indicates that the CPU is not running.There can be several causes for this:- Bad reset circuit- Ripple on power supply- Defective CPU
thanks Martin,
that does not sound very encouraging, to say the least :-(
looks to me the unit is ready to be parted-out unless there is another "cheap" option in store ??
hi martin,
looking at the wiring diagrams:
there should be 6.5V PC3/P11 pin9 supplying PC21/P29 pin11 with 6.5V but is only about 0.5V ??
I can however measure the 15V on PC21/P29 pin10 !
that is rather odd ??
