Beocenter7000 - Type 1801 Stuck in P mode
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Tue, Aug 13 2013 5:56 AM
greetings all,
I am having problems with my Beocenter 7000:
the display shows P and I can't change it, as it seem to be stuck in that mode/source.
is there any way of re-setting the micro-processor or another way of getting back to normal ??
naturally it could perhaps be something totally unrelated......... BUT WHAT ????
any help is appreciated
thank you so much :-))
cheers, ALF
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Aug 13 2013 6:09 AM
This indicates that the CPU is not running.
There can be several causes for this:
- Bad reset circuit
- Ripple on power supply
- Defective CPU
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Tue, Aug 13 2013 7:04 AM
thanks Martin,
that does not sound very encouraging, to say the least :-(
looks to me the unit is ready  to be parted-out unless there is another "cheap" option in store ??
cheers, ALF
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Tue, Aug 13 2013 3:43 PM
hi martin,
looking at the wiring diagrams:
there should be 6.5V PC3/P11 pin9 supplying  PC21/P29 pin11 with 6.5V but  is only about 0.5V ??
I can however measure the 15V on  PC21/P29 pin10 !
that is rather odd ??
cheers, ALF
Page 1 of 1 (4 items) | RSS
