BL8000 pls help
This post has 1 Reply | 0 Followers
acorrado
Posts 21
acorrado Posted: Fri, Dec 30 2016 5:28 PM
Hi Forum,
i need some help to understand if it is worth to replace my BL4000 with a BL8000 mk1.
actually the true question is if I can, and how, use both together.
i already own the playmaker and a dlna music server.
can you please advise which are the man differences between the BL8000 mk1 and mk2?
thanks in advance
Andrew
OldJack
Split
Posts 371
OldJack replied on Fri, Dec 30 2016 8:35 PM
Hi Andrew,
Difference mk1/mk2,search old threads for BL8000 like this one, http://archivedforum2.beoworld.org/forums/t/775.aspx
Do not get rid of your Bl4000, if you can,they are very,very good underrated speakers.
I use BL8000 as fronts,BL4000 as rears,Beolab2 sub,and BL7.1 as center,All connected to Beosystem 3 mk3.
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Page 1 of 1 (2 items) | RSS
