Hi Forum,
i need some help to understand if it is worth to replace my BL4000 with a BL8000 mk1.
actually the true question is if I can, and how, use both together.
i already own the playmaker and a dlna music server.
can you please advise which are the man differences between the BL8000 mk1 and mk2?
thanks in advance
Andrew
Hi Andrew,
Difference mk1/mk2,search old threads for BL8000 like this one, http://archivedforum2.beoworld.org/forums/t/775.aspx
Do not get rid of your Bl4000, if you can,they are very,very good underrated speakers.
I use BL8000 as fronts,BL4000 as rears,Beolab2 sub,and BL7.1 as center,All connected to Beosystem 3 mk3.
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
