Hi folks,
New B&O user here, just got a pair of H5 earphones to replace my Airpods. I just couldn't get the Airpods to seal properly in my ears so they always felt like they were about to fall out, and I didn't get the full sound from them unless I was pushing them into my ear, as soon as I let go they unsealed again.
I found the medium Comply earbuds to give me a perfect fit and seal with the H5's, and I love the sound.
My only niggles with the H5 are:
I only use my H5's with an iPhone and an iPad during my commute. Both devices paired perfectly first time, however I'm not sure if I'm switching between them properly. When I try to change from my iPhone to my iPad, I first try tapping the H5s in the iPad's bluetooth list but it always fails to connect even though they are already paired. I find that I have to long-press the middle button on the H5's, and THEN tap on the H5's in the iPad's bluetooth list. And the same when I switch back to my iPhone. Is this normal? Is there a faster way to switch between already-paired devices?
The iPhone BeoPlay app is showing I have firmware 5.0.7 on my H5's, I have never seen any updates available, is this the latest?
I really want to like these more, nearly went for the E8's because of the anticipated cable-noise but the E8's seem to be plagued with drop-out issues.
Any tips appreciated, thanks.
Charlie
i love my H5s, also use the comply spherical buds - just bought a new set of 3 as they are very comfortable. I have the same software version as you and it seems to be the last version.
i mostly use them with my iPhone, but when on a flight, I use them with my ipad. With both devices in close proximity, the H5s connect by default to the iPhone, so I have to switch the Bluetooth on the iPhone off, then go into the iPad and pair there. Once I get off the plane, I switch the ipad’s Bluetooth off - just to make sure the next time I pair, it will be with the iPhone.
it is more painful than using the AirPods, I know, but I really like the headphones - and I never get the cable noise that is often mentioned... don’t know why.
i just hope the battery lasts a long time, as I’ll be sad when they degrade too much to be able to use.
Don’t understand the question. Can you elaborate?
I had that problem with mine when I had a pair! Always thought it was just me doing something wrong.
Jon:I had that problem with mine when I had a pair! Always thought it was just me doing something wrong.
