Beocenter 6 Questions
This post has 2 Replies | 2 Followers
blidge
Posts 11
blidge Posted: Fri, Sep 13 2013 1:52 PM
I have a Beocenter 6 with built in DAB. A few questions that I hope someone may be able to help me with:
1) is it possible to listen to the DAB radio while viewing another source (probably will be PC via DVI)?
2) is it possible for another B&O item to use the DAB tuner via Masterlink while viewing / listening to another source on the TV itself?
3) I may be locating the TV in a room with another B&O TV. How do make the Beo4 control each of the TV's independently?
Thanks in advance for any help!
Regards
Brian
blidge
Posts 11
blidge replied on Mon, Sep 16 2013 7:48 PM
Bump. Anyone?
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, Sep 17 2013 2:57 PM
I sold my BC6/DAB years ago, so I don`t exactly know, but as I remember, it won`t work.
1- you can test it pressing RADIO (DAB RADIO should start) and then AV - PC.
2- If I remember correctly - no. BC6-DAB is meant as a local source...(?) If you have a link system, try to activate DAB from another room by pressing RADIO  (LINK _ RADIO?). BC6 should be set to V.OPT 2 (master).
3- Set one of your TVs to V.OPT 4. You will have to press LINK before you choose a source.
Hope this helps.
Stefan
Page 1 of 1 (3 items) | RSS
